RCU Forums - View Single Post - BALANCING PLANES
Old 10-26-2008 | 03:53 PM
darticus
Default RE: BALANCING PLANES
Thanks for all that great info. I'm gonna look for the CG machine. Would like to see how to balance from side to side. Maybe put two nails in the fuselage front and back.
With the small foamies I make maybe this balancing would help.
http://www.rc-airplane-world.com/bal...airplanes.html
I did mean side to side. I also wanted to know where the center of gravity should be? Is there a true spot? Where on the fuselage and wing do you have the CG? Apparently you could make the center of gravity anywhere by moving the plane innards but where should it be? Thanks Ron
