Need Help with a Veco .19
Hey Jaka,
Thanks for the response....
1. Good to hear.
2. Thanks, I'll check it out again for gunk. -- Nope on the black plastic carb .... aluminum.
3. Didn't know silencer was available -- I'll have to check -- any sources? (Failing that.... what does the linkage look like???)
4. Doesn't appear to be a ringed engine. I've looked in through the exhaust port and turned it over and can't see a ring. I'll have to run it a while longer. Like I said, I can only get it to run at about 1/3 throttle -- I'll have to check for debris and try again --
This engine is different than the others I have (GMS 25s, TT Pro 46, GMS .76). It doesn't have a low speed (idle) adjustment in the throttle barrel. Where is the low speed needle???
Thanks.
