RCU Forums - View Single Post - Funky chicken MVVS 58
Old 10-26-2008 | 07:44 PM
Jason Arnold's Avatar
Jason Arnold
Default Funky chicken MVVS 58
Hi Guy's,
My MVVS 58 is causing my radio to do the funky chicken i.e. servos jittering and IPD(MPX Rx) lock out.
The motor and radio have worked fine before and I have since made some changes to the CG by moving the throttle and choke servo aft and also moving the ignition about 20mm further aft. I have reversed all changes with exception to the servos but it still does the funky chicken. I'm using an emcotec remote control switch for the ignition cut and will try connecting the ignition direct to the battery and see if I still get problems. The pug cap seems to be fitting firmly and the plug is a CM-6 which came with the engine.
Any help would be greatly appreciated.
Cheers
Jason.
