ORIGINAL: goirish
ORIGINAL: MinnFlyer
ORIGINAL: bassfish
If you read the post, I said, I don't want to have to hack on one! That means that I wont one that I don't have to modify! I can't see spending that kind of money for a perfectly ballenced spinner and then butcher it up and then have to worry if it is ballanced or not. >>>-> [sm=shades_smile.gif]
First of all, who ever told you that spinners were balanced? Manufacturers don't even balance props (Which are much more critical), why would they balance spinners?
Second, Spinner manufacturers purposely make the hole for the smallest prop feasible for that size. YOU can make it bigger if need be, but you CAN'T make it smaller. So they are INTENDED to have their holes enlarged.
If you are really that set on not doing it yourself, contact Tru-Turn as Birman suggested and they will do the cutting for you - but expect to pay for the privilege.
OH!!! by Gosh!!! MinnFlyer you mean they don't balance spinners. Now I won't be able to sleep knowing that my spinner is not balanced. UGH!!!
I'll upset you even more. He doesn't balance he props either!!!!!
BTW, neither do I!!!
Ken
