RCU Forums - View Single Post - Cuban 8's: Tips and advice needed
Old 10-27-2008 | 02:29 PM
Adui
Default Cuban 8's: Tips and advice needed
So heres the problem, (Aside from the fact I dont get to fly much these days) I can not seem to get this maneuver down! I can do the immelman, and the split S. I dance acros the sky, pulling both on either end of the air field. But I try to put it together and do a cuban 8 and I lose it.
So, is my issue simply a limitation of my aircraft? (Flying an H9 Arrow Semi sim trainer) Or strictly a pilot issue?
Should I step up to a good second plane level sport model and try it then, or keep trying till I get it on the arrow? (Irrelevant since outside of my SPADSTICK build I cant afford this option)
A note: I am going to build a SPAD Stick next spring, so the 2nd plane level is covered, just curious if that is my failing or if the more likely, pilot error is the issue.
In either case, tips and suggestions are most welcome!
