RE: applying koverall with WBPU
only problem with doing that, is its getting pretty cold here in canada. soon it will be consistently about -10, which is way to cold to paint. i was hoping to use the WBPU and paint with latex. the fumes off this stuff is hardly noticeable, and i would only have to crack a window for fresh air. i only have limited access to a shop. but i was thinking about using the monokote clear spray for a top coat to protect the paint from fuel. i will be using a gas glow mix, so i might even get away with WBPU as a clear coat, cause i will be using little to no nitro in the mix. i think that tonight, i might try covering a scrap piece to see how it turns out. its an aileron from a scratch build that i have put on hold, so if i mess up, im not out very much.
