RE: Super Brain 960 Right Light
From pg 2 in the manual:
4.The first 30~60 seconds is the battery diagnostic period. LCD will display “test” and
the red light will flash during this period. The unit will not accept new commands during
this diagnostic period.
5.LCD will display “Charge” and the red light will remain on during fast charge. The
battery status and voltage are displayed.
6.The charge rate, time and voltage can be viewed by pressing the “Display” button.
NOTE: If the delta peak voltage threshold has not been set manually, ignore the display
for the delta peak voltage threshold. The value displayed is irrelevant.
7.Charging can be stopped at any time during the charge cycle by pressing the “Start”
button.
8.When the fast charge cycle is complete, the unit will beep three times and automatically
begin a 50-minute 0.1 Amp trickle charge cycle. During the trickle charge cycle “Charge”
and the red light will blink (with very short on time and long off time). After the trickle
cycle, the charger will automatically go into sleep mode.
