RCU Forums - View Single Post - what servos for mojo moass 60?
Old 10-27-2008 | 06:26 PM
Blade-breaker
Default RE: what servos for mojo moass 60?
ORIGINAL: Tigman
ORIGINAL: Blade-breaker
I am building a Moass 60 also. Futaba S3050 is what I plan to use all around (HS-85BB for throttle). Power for the servos will be a 3S lipo running through a Castle BEC http://www.castlecreations.com/products/cc_bec.html with the output voltage set at 6V. I choose these servos because of there weight, the higher output servos weight quite a bit more.
Keep in mind that even if you run 150oz servos but your battery voltage drops when the servos are under load you will have a huge drop in output power. It requires a substantial battery to power the HO servos.
My 40 sized Mojo was having blowback problems with my 6V nicd battery. Switching to the Lipo - BEC running at 6V cured the problem and also reduced weight.
Ryan
How hot does the Reg, get with the 3s lipo?
I have done some testing on the ground and the highest amp draw I could get was just under 2.5amps with (4) 9001's and (2) 9155's under full overload (on Ultra Stick Lite 1.20). Just warm was all I could get out of the Reg. Under what I think is normal loads I was showing around 1 amp.
When I mount the Reg in the plane I dont wrap in foam I just velcro it to a pc of foam. I have never had a problem.
Ryan
