Dumping the flaperon feature
Did you check if:
-servo horns are identical and pushrod is in corresponding holes?
-ditto for control surface horns?
-servo travel is identical for both servos?
it sounds like it's consistently one servo/linkage which has more travel than the other
If the radio is set to default as you indicate, it is most likely one of the above.
