RCU Forums - View Single Post - Need advce/suggestions
Old 10-28-2008 | 12:14 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Need advce/suggestions
ORIGINAL: Whirley Bird
ORIGINAL: bigedmustafa
The Hobbistar should be a good fit based on what you described you're looking for. The .65 LA is a good choice for power, too. It actually out turns the .61 FX on a number of different propellers. I'm flying a very similar setup, a Goldberg Protege .60 ARF with a Thunder Tiger GP-61 engine, and it's an absolute joy to fly.
Hi bigedmustafa
Now you got me set on it
OK I have all of the three TH RTF trainers.
This will be the biggest amd it does have ball bearing servos.
To be a little more specific what I want is a bigger plane that flies faster then the Avistar with a bigger engine but not at hyper fast speeds and still do the loops,rolls,etc at a little faster rate.
I like your sig line.
That was why I gave up the helicopters
Vegas/
There is no way the larger plane of very similar design will roll faster or loop tighter than the smaller version of it. The larger the plane the slower and more gracefully it will perform these manouvers. If you want to roll like a kids toy top and loop somewhere between the spinner and the tailwheel get a Twist
