ORIGINAL: Missileman
ORIGINAL: Whirley Bird
Hobbystar and Avistar will both do loops and rolls.
Vertical climb is strictly engine /prop vs weight.
Ummmm Ya think this will do vertical? STOCK?
71" span with a 13x5 prop and total weight around 9 pounds with fuel it seems to me it should.
Vegas/
It sure will with the right engine and prop. Stock with your .61 fs and a 13X5 prop should be decent vertical
Try a Tower Hobbies .75 with about a 14X4 prop maybe or even a .91 4 stroke and you can have almost unlimited vertical.
Vegas/
Well then if it will do vertical stock then i'll go for it
I just got the new EV 61NX but from what I been reading the OS65LA on the big trainer will do better.
4 Stroke sounds good but funds here are low
Vegas/
