RCU Forums - View Single Post - Could use some help for throttle hook-up
Old 10-29-2008 | 07:12 AM
goirish's Avatar
goirish
Default Could use some help for throttle hook-up
I am mounting a magnum 180 4 stroke on a Big Bingo. Problem I am running into: As you can see by the pictures the throttle level is too high to run the cable. Can the throttle lever be turned around and if so, how? I don't see anything but what I believe is the LSN screw. Thanks. I can provide more pictures if that will help.
Gene
ID:	1061419   Click image for larger version
