2-Stroke Engine Reversed HELP!!
The reverse crankshaft changes the timing on the engine. The timing is determined by the placement of the intake window or port. The intake port on the crankshaft is machined on the other side of the barrel of the crankshaft on the reverse crank. The threads for the prop are probably reverse also. It is basically a mirror image of the standard crankshaft.
