Case Offset?
If I remember correctly the SF has a two-piece case. Is the front housing turned 90 degrees from vertical as compared to the cyl.? If the previous owner used that method to reverse the rotation you could simply return the housing to normal. At least worth looking at. Take care, Cliff
