RCU Forums - View Single Post - Could use some help for throttle hook-up
Old 10-29-2008 | 08:58 AM
Rodney
Default RE: Could use some help for throttle hook-up
I often use the method Ken suggests, works very well. It also allows you to bring the throttle pushrod out right next to the fueslage side (easily missing the fuel tank) then up and back to the throttle arm. On some you may want to put a guide on the side of the fuse just before the bend so minimize any movement due to vibration.
