RE: Walbro HDC carb question
Hmmm. What size prop do you run and what RPM is it turning wide open. Kind of sounds like it may be overheating as you state that back to half throttle it picks back up. Could the high needle be too lean still? Your plane isn't cowled in stock configuration so the hole in the cover may or may not be an issue. you would need to run the tube inside the fuselage.
