RCU Forums - View Single Post - Prop continues to fall off
Old 10-29-2008 | 03:48 PM
Alex7403's Avatar
Alex7403
Default RE: Prop continues to fall off
my props fell off when there was too much fuel in the cylinder, it caused a hydraulic lock so the prop fell off.
in this case you unscrew the glow plug and swing the prop few turns.
other things, do you have prop washer?
do you have plastic spacer between the spinner back plate and the shaft, some spinners need that?
as mentioned, instructor is the best resource.
good luck
Alex
