RE: SKYMASTER-USA MIG-29 FIRST LOOK
From what I noticed it takes a bit of pressure to unlock and lock the gear.
l locked the gear in the down position with air pressure and then disconnected the line. I then tryed to retract them by hand and they did not budge at all. If the system ever leaks down you should not have a gear collapse due to the way that the locking mechanism works.
