ORIGINAL: Tired Old Man
Plug angle can for sure be an issue when it comes to cowl fit but there's often a "fix" for that. Many engines use a 14mm plug which also requires a tall plug cap. You can install inserts to reduce the plug size to 10mm and use a smaller plug and cap. You might end up changing the compression ratio fractionally but if we're needing every erg of energy an engine can deliver we needed a larger engine anyway.
Good idea Pat. Come to think of it, didn't Milton do a thread on this a while back? Here's a link to a thread with pics of the DZY 48. Posts #173 and #175.
[link]http://www.rcuniverse.com/forum/m_4690850/mpage_7/key_/tm.htm[/link]
