RE: PLEASE HELP WITH ESC!
I set my low voltage cutoff for soft reduce power and if available on my ESC I also set it to the highest voltage setting so I don't run my lipos too low.( no cut should be ok as long as it has a way of letting you know the battery is low)
You absolutely want the brake off on a helicopter and you want soft start
