RE: 2.4 ghz Jammers
If someone wants to jam 2.4Ghz and more use a microwave... Have you ever tried to use your house phone, bluetooth, etc... when your microwave is running? It does not work at all usually with a little leakage while in use. All you would have to do is open the door, fix the sensor to fool the switch thinking the door is closed and punch in what ever amount of time you like just about. But if I get jammed being within 30' to 50' with it being shielded I cannot imagine how far it would kill the signal then, 1200watts I would think would kill it for at least a city block.
