RCU Forums - View Single Post - OS 55AX
Thread: OS 55AX
Old 10-31-2008 | 07:37 AM
DarZeelon's Avatar
DarZeelon
Default RE: OS 55AX
Togatoga,
I have no doubt no sliding joint will live for very long without lubrication...
Once you choke and turn the engine over to prime it, sufficient lubrication gets into the con-rod's lower end, for the engine to be started safely.
Regarding the redeposited debris, plugging lube-holes... You are correct!
