Need Help to Install Tail Rotor blade.
Well I broke the tail rotor blade on my Cpv3. It's a press fit on to the motor. I've already broke one new
blade trying to push it on and probably have messed up the second one because I drilled it out a little.
The fit is so tight I think it would take a 50 ton press to push it on the shaft. Then the motor would be
crushed too. Anyone know the proper way to do this without causeing damage to the motor. Any ideas
are welcome. Thanks.
