RCU Forums - View Single Post - Need Help to Install Tail Rotor blade.
Old 11-01-2008 | 03:56 PM
A. J. Clark's Avatar
A. J. Clark
Default RE: Need Help to Install Tail Rotor blade.
propjetdriver
I beleave I found a better way to install the tail rotor. I used a 2" c-clamp and a piece of balsa wood
1/8 x 3/4 x 3/4. Put the piece of balsa on the opposite end of the motor for support then tighten the
c-clamp enough to start the blade on the shaft. Then back off and get everything squared up again.
Then press some more. Make sure you keep things squared up. Do this 2-3 times and you there.
Worked good.
