RCU Forums - View Single Post - PLEASE HELP WITH ESC!
Old 11-01-2008 | 05:16 PM
hamid_fireage
Default RE: PLEASE HELP WITH ESC!
Hi funflier - Motor gets warm about 110-130F, the esc 140 to 150F and the battery about 160(after 7-8 mins of hover). Im using the stock battery and the e-sky 1500mah 10c and the two tx knobs are at about 3 O'clock. Do you think this is just because of the battery's low discharge rate or the non-switching bec too?
And how is that stiffener? Did you make any other mods to instal that 3800 motor? Cause im running it with a 10t and it didnt mesh correctly with main gear so i filed the back of the motor about 0.5mm with a needle file. I also used a hand made spacer(2.2mm thick).
ID:	1063539   Click image for larger version
ID:	1063540   Click image for larger version
