RE: How do you apply Titebond or other Aliphatic glue?
For LE sheeting, I've taken to Gorilla glue. Put just a very thin bead along the rib, spar, and LE spar. Lots and lots of blue tape and tape the sheeting in place. The glue will foam up and fill any gaps and it is not that dificult to clean up after it sets. Just shave the foam out off with a Xacto knife or razor plane. Then you can sand down glue joint. Make sure you wipe up any foam out when it starts to kick off. If you use just a very fine bead, there will not be that much foam out anyway.
Don
