RCU Forums - View Single Post - Remote Needle Vavle
Old 05-28-2003 | 07:27 PM
paul_c
Default Remote Needle Vavle
I had the same problems with bubbles seemingly originating in the RNV. I tried changing the little O-ring on the needle valve, but no better. I put zip ties around all the fuel outlets (nipples), but no luck. It turns out that I had inadvertently round down the tiny lip on one of the nipples, when my screwdriver ground up against it as I was trying to tighten one of the engine mounting screws.
Don't give up! Try the things I said above, and good luck! I was going nuts over this.
