RCU Forums - View Single Post - engine problems!
Old 11-02-2008 | 10:01 AM
OLD_SLOW and in the WAY's Avatar
Default RE: engine problems!
what oil and ratio are you running?
do not use outboard oil
you might have stuck the ring, if the bore isnt damaged just get a new piston/ring then have a buddy with a lathe take .002" off the diameter of the piston down to just above the wrist pin hole
