RE: nitro model .40 ultimate bipe
Be careful with those quick fuellers, they can be quite problematic.
I'd recommend a "T" or a 3 line setup instead.
20% Nitro is a bit of overkill for most .46 engines. Most will run well with 10%, and 15% makes it a bit easier to tune. Likewise with the equivalent in 4C engines...
Starting off with 15% on a newer engine may be advisable, then later you can work your way to 10% and save the difference.
