RCU Forums - View Single Post - I converted a glow engine to run on E85
Old 11-02-2008 | 09:35 PM
  #108
av8tor1977's Avatar
av8tor1977
Default RE: I converted a glow engine to run on E85
Unless an engine has a compression ratio too high to support it, and unless it has a too hot plug, nitro will benefit in many ways, including power, idle, and idle to high power transition. If the compression ratio is too high, or the plug too hot, you will encounter detonation, possible engine damage, and burned out glow plugs.
AV8TOR
