RCU Forums - View Single Post - 4*60 Aileron Servo
Old 05-28-2003 | 03:03 PM
CRFlyer's Avatar
CRFlyer
Default 4*60
I built mine per plans. The servo arm should be centered b4 you head to the field. This then should not need to change. I used a standard pushrod with a Z-bend at the servo end, and a clevis on the aileron end. You can then easily adjust the ailerons by moving the clevis in or out.
