4*60 Aileron Servo
That's right. Once the servo horn is installed at the 90 degree neutral position, it should never be moved. If adjustment is necessary, do it with the clevis.
I don't like to solder either, but I usually solder the clevis once it is trimmed. Otherwise they will eventually loosen.
Tom
