RE: Y LEADS
The Y connector allows you to run dual servos off the same RX channel.
If its dual aileron servo setup out on the wing the linkage is setup such that the pushrods are attached to the control horn on the opposite side of the other servo. That way the movement is made in the opposite direction with one aileron going up while other goes down. Hope that helps.
