Originally posted by MajorTomski
I have heard in the past that NiCads should not be hooked up in parallel because of their low internal resistance. If one cell is at a lower voltage than one in the other pack the higher voltage will try to drive the low voltage pack like a resister, causing a thermal runaway in both packs.
This only becomes an issue when charging. Never charge batteries in parallel.
