Is epoxy a must?
Good evening all.
Throwing together another ARFT at the minute, and after gluing the wing halves together using cold thick 30min epoxy, I was wondering of a suitable white glue would work as well? The Glue I have is waterproof 'wood glue' slightly flexible when dry (much the same as 30 epoxy) but much easier to get to soak into the wood. Any thoughts??
I am not sure if this is the same as (elmers???) yellow glue that you use over the pond, all I know is that t is a polymer UPVA glue.
Cheers!!
BC
p.s. Wasnt planning on using for joining wings, just to glue the vert and horiz stabs in place!!
