Set Screws
I have had this problem a bunch of times.
I believe it is the set screw that is on the wheel collar that holds the 3/16 wire in the gear block. It touches the end of the retract just enough that it will sometimes bind on coming down. Just turn the wheel collar on the 3/16 sideways a bit or grind a bit of the set screw.
I hope I explained it correctly.
Adil
