RE: servo plug replacement
Yup, the tool I posted works great. Having crimped countless connections from Mod8 to various fiber connections, I can tell you the key to any crimp type connection is the tool. This one has an adjustable ratchet tension. Once it is set, every crimp gets the same pressure no matter how you squeeze the tool, so perfect every time. The pliers type of crimp tools belong in the dust bin. The one I posted may cost more, but if you plan on making your own extensions etc., it is worth every penny. I can solder pretty good too, and soldering is harder than this tool. Grey, don't sell yourself short, if you've mastered soldering, I'm sure you could easily use this tool just fine.
