ORIGINAL: terrymf
I understand what your saying except for in your suggestions..
3) To install turbulators close to the wing tip s.
4) To short the ailerons from the tip s as much as possible
Could you elaborate a little on these points?
What are tubulators?
By "short the ailerons" Do you mean to take away some of the aileron material at the tips?
and then..
5) Not to use ailerons during landings.
I only wish I were that good of a pilot..I know I would mess that one up.
I cant even do that on a h9 Alpha trainer (or a nextar, or a tower trainer or a (insert your easy to fly plane here)
Check this:
http://en.wikipedia.org/wiki/Turbulator
Yes, that is what I mean by short ailerons.
Yes, you can do it; just practice much, the rudder is very useful.
Regards!
