RCU Forums - View Single Post - servo problem
Old 11-04-2008 | 08:30 AM
cyclops2's Avatar
cyclops2
Default RE: servo problem
Do you mave ANY metal to metal contacts ANYWHERE in the control rods?
Metal pushrod in a metal connector? Metal connector in a metal control horn on a surface?
Metal pushrod with ANY metal guides?
Antenna wired coiled up inside of the body? Antenna wrapped around or laying within 1" of the metal pushrods?
Rare......Try another Xmitter. Do a range check OUT DOORS. Sometimes indooor tests go wacky because of metal siding or metal heating pipes or ducts. They bounce signals back & forth ...out of time.
More rare. Change both the transmitter & reciever crystals. 1 at a time.
If none of those help.
Change the pilot.
