RCU Forums - View Single Post - os wankel starting problem
Old 11-04-2008 | 11:45 AM
TFF
Default RE: os wankel starting problem
I would double check and take out the plug and see if it is glowing and after you reinstall it squirt some fuel directly in the carb. and try to start it. What fuel are you using? I guess they use the FS plug now; the older one used a special plug.
