RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-04-2008 | 01:28 PM
  #832
MHester's Avatar
MHester
Default RE: Black Magic VF3 Build Thread
Hey John, make some dust!
The YS set up is super straight forward with this plane. I'll see if I have any pics I can dig up for you.
basically you want to use one of the ARxx mounts and a nose ring.
use a hatori 821/822 set up for exhaust and just mount the soft mount for the muffler on the bottom plate of the fuse right in front of the gear plate.
Clock the engine 5-6 degrees or so and you won't even have to cut a relief hole for the header. ALWAYS use an anti-knock glow driver to avoid the dreaded kick...
Other than that, think cooling...
-Mike
