Phaeton 90 Build
Need Help; I am finishing a Phaeton 90 (Balsa USA) that I bought at a swap meet a couple of years ago. I have most of the plans. The wings and fuselage were built although I had to do some fix up since the original builder built straight but made several significant structural errors.
My question is: Does anyone have plans that include information on the prop shaft thrust line and the position of the engine/mount on the firewall. I didn't get that part of the plans (they were cut apart). If available I could also use the fuselage top view from the plans.
I would be willing to pay both duplication and postage. I can guess at the engine position if necessary using the cowl position as I did on a rebuild of an L-4 Grasshopper but I'd like to avoid it if I could.
Thanks for your consideration,
Steve
