Secondhand Super Tigre engine
Well 2 fellow Aussies can't be wrong, even if they are living in the wrong side of the country.....
Yes I agree it is a good deal for only $50. It started first go on the bench and ran well across the entire throttle range. I will check everything out that has been mentioned above.
Can the carby be taken apart easily enough and cleaned? How critical is the direction of the spray bar outlet that these engines have?
Troy.
