RCU Forums - View Single Post - YS 120 SF regulator problem
Old 11-05-2008 | 12:09 PM
dmccormick001's Avatar
dmccormick001
Default RE: YS 120 SF regulator problem
Sounds like you might have developed an air leak. Check all the o-rings and gaskets. At high speeds it isn't changing the air/fuel ratio enough to make the engine quit, but at lower RPMs the extra air is making the engine lean out and die.
David
