Replacement USB cable
Hi Mike,
I recently received the replacement usb cable and it is working perfectly.
Thank you again for your support.
The cable that I received is "part#IK3024001 Replacement USB cable old" and is working perfectly.
The Aerofly Pro Deluxe version that I am running is 1.11.07.21.
My question is.
Since it is the old version in a plastic case (not heat shrink) will I run into problems if decide to get ADD ON #4 or future ADD ON's?
Is it only the pakaging that is different or is the electronic different?
Thank you
Michel B.
