RCU Forums - View Single Post - alignment of wing, fuselage and tail surfaces?
Old 11-06-2008 | 11:27 AM
Popriv
Default RE: alignment of wing, fuselage and tail surfaces?
When flying this plane I had noticed that in a loop it tracked off to one side. (could have been my lack of skill!) I hadnt checked these measurements before the crash but I could see that if these surfaces were off, especially the elevator, a loop would be more of a cork screw?
I didnt think 3/16" would be to bad but when they say make it as straight as you can, well, given enough time and effort, it could be made perfect.
So, wing is done and I'll mount the tail surfaces tonight. They bolt on but I'm going to enlarge the holes slightly. cut back some covering and use epoxy along with the screws. I can then align the tail to the fuse, tighten the screws and let the epoxy do its thing.
thanks
Steve
