RE: Spark ignition on YS170 DZ
Chris,
My understanding is ignition and low oil are independant of one another. Just applying ignition does not allow you to run low oil content, you need to ensure your 170 has the appropriate internal parts. If you pull the cam gear cover off the cam follower should have a spiral groove on it, if not then you do not have a low oil 170.
