RE: Is epoxy a must?
Before PICA when out a business, I used their Glueit. They actually had you do a test between it and epoxy, using two pieces of plywood. I could break the plywood but never the joint. But, I still admit I use 30 minute epoxy for gluing wings together and Titebond II for most everything else. I try and avoid CA as much as possible.
