RE: Boomerang Sprint Build Thread!
Hi John,
I have flown DVF's for about 10 years and believe it or not I never used flaps or did any mixing. I know that will change with my Sprint but here is the question. Would you suggest not using any mixing on the maiden flight? Additionally, since I've never really used mixing much except in Heli's, can I only assume that once the flaps are deployed causing the nose to drop, the mixing with the eleator up will stop the sudden drop? Is that about the right thinking?
Thanks for your help,
Doc...
