ORIGINAL: huejohnson
could some one tell me if there are any new cb for the monsoon other than redcat ones. thanx a 12 tooth would be nice
A lot of folks would like a Replacement for the (rather odd) elongated clutch bell.....
The SHORT story is that there is NO aftermarket replacement for the Redcat Clutch bells.(Redcat Does make a 12 tooth bell, which makes it easier to drive on the larger tracks.)
The LONG story is that you CAN mod your Monsoon to run another MFG Clutch Bell (the standard Short kind), and use a Bump Box too, but it is a LOT of work and you had better be prepared to search for parts on the internet and you need to be Handy with a Dremel....
The only reason you would do such a thing is if you are Racing and IMHO, it is not worth the time, effort or cost.
Race it the way it is and make some reasonable mods, (quality bearings, Tires, shocks, brakes, servos, radio, and Tiger Drive). When the engine goes, drop in the 6 port piston/sleeve mod. If you drive well, you can be competitive at the Club level.
